lawmanbsi
Selling my 136" mono out of my 06 Attak. Another member was wanting to know if it will fit into his RX-1. What would he have to do to swap it over? Also will the Attak tunnel extension fit on RX-1 as well?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I do believe they are the same tunnel, and it may bolt right in place.
- Nov 9, 2008
- 2017 Sidewinder LTX
If you supply the mounting brackets and the tunnel extension as well as the location to those mounts it will bolt into an RX-1.
lawmanbsi
planning on changing to an Expert X. Everything needed for mono will go.
- Nov 9, 2008
lawmanbsi said:planning on changing to an Expert X. Everything needed for mono will go.
Then whoever is buying it should be in good shape.
