06 Attak rear shock
vt black rx1
vermont
Got my shock back now i was woundering what i am gone to get when i move the clip too second spot and pull up the limter strap too second hole ,I read alot but cant seam to find it now thanks FROM VT ATTAK
not knowing why you got your shock back, i say the clip position is based on your weight. I weigh about 240 plus gear and i run the second clip with a stock shock , second hole on the limiter strap and RARELY bottom. This setup works for me with minimal ski lift /weight transfer , i also have my transfer rod set towards the min. i run an 07 apex er.
