drfbuster
I took my Attak out for a ride the other night and It had snow and ice stuck to the underneath of the tunnel and was sagging way to much in the rear. is this normal for this skid and suspension? I also have the stiffer spring and set to the hardest setting on the dial. Thanks! drf
Ported Hornet
They have a tendancy to pack full of snow and ice. Put it in your garage and let it melt down, that will fix your problem.
yamadog1
ice
you should have your shock checked, it may need to be charged
CaptCaper
- Jan 1, 2007
- Northern N.H.
some have posted that the optional rear cooler melts that stuf..others have had similar buildups..I put one in.
