06 attak stock with 500 miles, need help setting up suspensi
bolognarx1
Nova Scotia, Canada
:4STroke: I am a 250lbs fella and bought a second hand 06 attak with 500 miles. i find that the suspension is not set up for a guy my size. Was wondering if there were any of you were my size and could let me now where i should have the supenions settings dialed in at. also, is it normal that the limiter strap has a bow in it, and not tight when the sled is sitting on level ground?
Thanks in advance! Love this site! great for advice!
The first thing you MUST do is replace the stock shock spring with a larger one and have the shock re-valved. Until you do that there is nothing that you can do to setup the rear suspension that will work for you. I played with mine as much as possible before the changes and accomplished very little. My limiter strap does have a slight bow in it while sitting flat. I also bought used clickers shocks for front end.
spring is around $100 and the revalve is $48 plus shipping. I got both at pioneerperformance.net.
Just give him a call and he'll figure out what you will need.
