mmdtraveler
I have an 06 Nytro ER and sometimes when I brake there is a loud clunk, anyone got any suggestions?
wayno
- Nov 23, 2005
If you have reverse, it is the slack in the jack shaft that is necessary for shifting into reverse. When braking hard, it takes up this slack and causes the clunk.
mmdtraveler
ok, that makes sense. when shifting into reverse sometimes it grinds and wont engage, how do I remedy that?
Stu
- Nov 27, 2006
- Newberry, MI
- 2005 RS Rage
I don't know about grinding when going into reverse, but I know on my '05 Rage that it will not go in sometimes. The remedy is simply to rev the sled until it moves foreward slightly. What's happening (at least with my sled) is the gears are not lined up enough to engage and moving it forward slightly will change the alignment. Hope this helps.
P.S. OutRAGEous! - Please fill in your location as per site rules. Thanks.
TrailxRider
Stu said:I don't know about grinding when going into reverse, but I know on my '05 Rage that it will not go in sometimes. The remedy is simply to rev the sled until it moves foreward slightly. What's happening (at least with my sled) is the gears are not lined up enough to engage and moving it forward slightly will change the alignment. Hope this helps.
I have to do this with my nytro to go in reverse sometimes. It works for me.
