06 Nytro Fox Floats
ONH20BY5
Neenah Wi
Does anyone know many inches the front Fox Float shocks on an 06 Nytro is suppose to measure on the sled I know they are 17 and 1/2 inches off the sled, I just bought the sled and the front end seams very low, I was wondering if the shocks need to be rebuild, any help would be greatly appreciated ,Thanks Rick
with somebody on the sled the arms should be flat across or angle up towards the sled slightly,we run anywhere from 65 to 85 lbs of air with the weight off the front end.
Rick, most guys are running whatever pressure is needed to achieve level a-arms. How much is required to do that will depend on what you have going on for skid adjustments.
Determining if they need to be rebuilt or not shouldn't have anything to do with the front ride height?
shouldn't unless the chambers are blown,is that possible?
Not if they're holding whatever pressure is required to level the a-arms?
Nytro Shocks
Thanks For the advice I appreciate it, I found that the shocks were low on air , once pumped up it sits normal, thanks again
