06 nytro maximum lug height
Zomboskid
Waukesha Wisconsin
18 Sidewinder BTX
86 SRV 540
i got a nytro with 7.5 in. Rail extensions to make it a 136" track. The only problem is that it has a ski-doo track on it. I was looking at tracks and I don't know what the tallest lug I can have is. I know it came with a 1.25 from the factory, but does anyone know if I can put a 1.5 in. Track on it, or would that be too tall.
Thanks!
You can do a 1.5" on the 06 Nytro. But that is the max without removing the front cooler protectors. If you remove those you can go up to 1.75". 2" you would risk contacting the front cooler, or coming in contact with the exhaust system. This all assumes you have removed the tunnel protectors.
Ok I was only planning on going up to a 1.5" anyway, but thanks for the info!
