fraser.911
- Oct 3, 2008
whats the tallest lug height u can run on a 121inch nytro??
			Phyxius74
Without removing the tunnel protectors you can't go bigger then 1.25" without notching the lugs. If you remove the tunnel protectors I think you can go atleast to 2". Know a guy who did that.
			YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
I seen someones thread saying they are running a 2inch notched track with the tunnel protectors still in cause he didnt want to cut anything away from his new sled.
			sleddingfarmer
I just installed a two inch camoplast challenger that is "notched" and it clears everything no problem. That is factory notched too, Not cutting it with a knife or whatever.
If you want to run a taller lug and keep your tunnel protectors to stud the track, You could run a 1 3/8 track from a arctic cat zr 900. Look on ebay, they are on there under 500 dollars for brand new ones. Or there is a brand new 136" on tracksusa.com
I'am running a 1.5 camoplast Intense track, I did have to notch the track for the heat exchanger.
			Zakre
sleddingfarmer said:I just installed a two inch camoplast challenger that is "notched" and it clears everything no problem. That is factory notched too, Not cutting it with a knife or whatever.
I want that track in a 2"x144" notched, do they make one? not having any luck finding the part number so far, any help?
sleddingfarmer
they have them here http://www.tracksusa.com/challenger2.html
Probably the cheapest place you'll find it too. All the searching I've done for tracks and they were the cheapest. Unless you find a good used one on ebay of course.
