Dan S
- Dec 12, 2016
- Waterford wi
- Apex
When trying to start orange light comes on and engine appears motor does not turn over and now it appears to have a code 11
07 apex changed oil won’t start. Turn key hear fuel pump gages lite up.
Did you put oil back in? Sounds like something is not plugged in correctly.
https://ty4stroke.com/attachments/fault-codes-jpg.77941/
Dan S
- Dec 12, 2016
- Waterford wi
- Apex
Yes..there’s oil in it. I took the Air box back off and checked fuses connections etc...? I may have set the code off testing things turning key on with things not all hooked up...?Did you put oil back in? Sounds like something is not plugged in correctly.
So at this point what are we getting? It turns over but it wont fire? or it wont even turn over? Clicking noises? More details please.
Dan S
- Dec 12, 2016
- Waterford wi
- Apex
Dan S
- Dec 12, 2016
- Waterford wi
- Apex
The problem was the three wires for the starter solenoid there was some green stuff going on.. clean those up problem solved..
Perfect!!
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
I was going to suggest you check those relay wires. It may still do it later on. If so I have a whole post on cleaning those wires by getting them out of the connector. A new relay may be neededed too.
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
