01and02srx
I just got an 07 Attak GT should I worry about a fuel additive to compensate for this gas with ethanol?? Or is that just a 2 stroke thing
Turk
Tech Advisor
How does your car run on e-10?
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
01and02srx said:I just got an 07 Attak GT should I worry about a fuel additive to compensate for this gas with ethanol?? Or is that just a 2 stroke thing![]()
What kind of fuel additive are you talking about? What do you think you need to compensate for?
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Your sled will run just fine on 10% ethanol gas. No need to add anything or worry about anything. Just ride!
Preacher
The problem with e10 is if it sits all summer in your gas tank without proper fuel treatment it will separate from the gasoline. This can cause the ethanol to act as a solvent and if there are any impurities in the tank (rust,dirt,water) it will break it down and this can clog injectors or carbs . You will be fine if you properly treat the fuel with Stabil marine or K-100. Do not use heet or any alcohol type water remover.
