'07 Attak GT electronic shock wiring problem
Central Iowa
Website
gfir.ws
Guys,
Got my Ohlins shock back from Pioneer, now putting the skid back under my daughters Attak GT. Electronic shock adjustment isn't working. I need help figuring out why. Here's what I know so far:
1. Fuse is good (10 amp fuse)
2. Mode switches to shock adjustment mode ok. When I click up or down the gauge indicates up/down but the shock does nothing.
3. Checked the voltage at the shock plugin while using the mode & adjustment switch- no voltage (not sure how much it's suppose to be)
4. Continuity check the white wire on the sled side - good to the front side of the fuse holder.
5. Continuity checked the grey (ground) to engine - has continuity. To me that means wires aren't broke.
6. I have the plug off the sled side - if I plug EITHER wire into the correct plug of the Ohlins side, I can set the mode switch (which again makes me think wires aren't broke)
What should I check next? How much voltage should I expect to be seeing?
Thanks!
Bob
