2007 attak gt electronic shock
snappy
mass
I had my rear suspension out while the track drivers and shaft were replaced. now I can not get the shock mode to come up on my pod for adjustment only the grip mode is available. any ideas? Thanks
The guage pod has a poor/ lost connection with the shock. Same symptoms occur when the wire breaks. Check all connection points. And when servicing the shock or wire, always make sure the guage pod has a good connection to the shock before you tighten everything back up and zip tie the wire. Ihope this helps.
