SRXSex
The question is how close you guys think I am for setup on my 07 Apex GT.
I weigh 210 fully geared up. Aggressive trail rider.
Front spring pre load 55m of thread or 230mm spring length with driver.
Front compression dampening force 6 clicks out from max.
Front rebound dampening force is 11 clicks out from max.
Rear spring preload is set to 262 m and compresses to 230, Aprox 32m of sit on it.
Rear rebound dampening force it set to 25 clicks from minimum.
Rear control rod transfer is set half way between min and max.
I have not had a chance to drive it, so do you think I am far off or what??
Suggestions welcome.
welterracer
We are about the same
I left my front shocks alone.. I only added the 5.5 rear spring to my GT and set it at the LOOSE setting..
WOrks perfect..
WOrks perfect..
Front Shock Settings
What are the come from Yamaha settings on the front shocks on the 07 Apex GT?
SRXSex
Re: Front Shock Settings
Factory is 7 clicks
gt4472 said:What are the come from Yamaha settings on the front shocks on the 07 Apex GT?
Factory is 7 clicks
TurboJamie
I use 4 scales to set the sled up like a race car. All digital scales on 4 corners. Then balance the sled out with spring pressure. Sometimes one side requires more or less pressure.
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
a7m266d said:I use 4 scales to set the sled up like a race car. All digital scales on 4 corners. Then balance the sled out with spring pressure. Sometimes one side requires more or less pressure.
Interesting! Do you do this with or without your weight placed on the seat?
Apsterbobed
i would also like to hear more about this scale setup
SRXSex
The scale set up thing is easy. First you need a set of digital scales that the stock car guys use to scale the late models or modifieds (around $2K). Second you adjust your skis so equal pressure is applied to the two front scales. Do it with rider off first, then re do it with rider on. For the rear I cant see what difference it makes except to verify that both scales are equal at the #*$&@ end.
