canapex
Anyone know how big of a track you can get away with on a 07 RTX.
1.5 inch will it fit,anyone try one?
Thanks for any help.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Yes but your best to remove the tunnell protectors or take a utility knife and notch the track above the windows or she will rub slightly.
canapex
sobfrogg
An 1.5" track will fit. I have one on my Attak and I had to remove the tunnel protectors.
If you want a taller track you will need to change drivers and then some gearing changes.
canapex
sobfrogg said:An 1.5" track will fit. I have one on my Attak and I had to remove the tunnel protectors.
I am geared 22/38 already.Do you have to use differant drivers with a 1.5 track? Never heard that before.Is THAT RIGHT??
sobfrogg
You can use standard 9 tooth drivers w/ an 1.5" track. I did install Extros to get rid of the ratcheting.
My comment was regarding if you want a taller track than 1.5" 1.75", 2".
