07 RTX Lube Points
energeezer
Hi
I've got an 07 RTX which has the dual shock rear susp.
Can someone please tell me how many lube points (grease nipples) there are on the rear skid and where they are located?
Also I'd be interested to know where the other chassis grease nipples are located.
Steve
It shows them in the owners manual, but if you dont have them you could see them all quite well under there. Just look for any pivot points. There is one on ski spindles too.
All pivot points except the lower rod that holds the transfer rods. There is also one on each side of the transfer rods itself.
