07 Vector Handlebar risers
rjwest
I just purchased an '07 Vector and was wondering if you were able to put 2 inch handlebar risers on it without getting new cables? Are you able to re-route the cables to make them long enough?
You'll be fine with a 2" riser without changing the cables. I think 2" is about max unless it articulates forward. Anything more and you may end up needing to do something with the cables.
If you search on this site you will find a lot of posts on this subject. I think you will find 2" is typically what most say is the max. I put a 2" ROX pivot riser on my 07 Rage and dont see how one could go any higher. I have my bars pushed forward which uses less cable and I still had to remove the strap that holds the parking brake cable. I also dont see anyway to reroute any of the cables on these sleds for more slack. All the cables come up and lay on top of the steering hoop and up to the bars. It looks pretty straight forward to me. G.B.
