apeddigrew
Pls Help, I have searched 60 pages so far and no sign of any similar problem. CC Oil was / is milky & thick (cold). The sled still moves but makes very loud clunking sound every 4-6 feet. Is it possible the chain is just loose? (wishful thinking i guess). Does the oil resevoir need to be removed to get at the tensioner? Is anyone aware of any threads with info or "how to" steps to remove/replace/check chain or gear condition?
Thks Much! ap
Thks Much! ap
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
The white/milky oil is water/moisture that got into the oil. This could be the gasket or I have even herd that some experience this when they go from outside into a heated garage. Water condenses on the inside and gets into the oil.
This track change guide should help you out with getting to and fixing the problem.
Just skip any steps that talk about the skid/track.
I also attached a steps on how to adjust the chain tension.
Hope this helps.
Hope this helps.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
With water in the case I would check the bearings, seen water get in by the seals.
- Nov 1, 2009
- 2009 Phazer RTX
APEX 06 said:With water in the case I would check the bearings, seen water get in by the seals.
Yes water can also get in by the seals. Might as well change them also while you are in there...
APEX 06
- Apr 30, 2009
- Sheboygan, WI
They are pressed in and out
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Not sayin nothing isnt wrong in the chaincase, but check your drive belt, just a thought..
xt_gt
no need to remove oil res.
maybe check your secondary to see if you broke something.
porkchop
yamahinn03 said:Not sayin nothing isnt wrong in the chaincase, but check your drive belt, just a thought..
Yep, a cog or 2 missing/worn down will "ca chunk".
Blew the original '07 belt @ 82mph last year and got the thumping feeling, thought the whole motor had grenaded. I was like ,"oh WTF did I just do"!!
Wife pulls up behind me 30 seconds later and gives the womanly, "why do you have to be running that fast anyways" lecture.
"Simmer down woman, it's a nice flat straight and happens when your're having fun".
She needed a smoke break anyways..........
Now wait till I buy a new belt @ $100 this year
apeddigrew
07 VL Chaincase
Thks very much. But i can't see / find the "track change guide"?? Still pretty new to the forum.
thks again,
ap
thks again,
ap
yamahas said:The white/milky oil is water/moisture that got into the oil. This could be the gasket or I have even herd that some experience this when they go from outside into a heated garage. Water condenses on the inside and gets into the oil.
Hope this helps.
- Nov 1, 2009
- 2009 Phazer RTX
