dukemerc
- Dec 7, 2012
my last ride out last year the banjo bolt came loose and i lost the oil and gas out of my center shock i live in new jersey would pioneer be a good place to send it for a revalve and service? thanks duke...
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I normally send all my shocks to Pioneer because they're only 45 minutes away and typically get the job done in a couple days at a reasonable cost . Hygear is located in NY and also does good work. All the shocks on my Nytro RTX have been revalved by Pioneer but I run Hygear's dual rate spring on my center shock and I'm happy with the results.
jb_008
- May 21, 2012
- Sault Ste. Marie, On
- Yamaha Nytro RTX SE 09
Personally I had mine done at Schmidt Bros motorsports in MI. They replace the line with a braided line, re-valved it, and put a custom spring all setup for my weight. They also do the rear shock too at the same time if you want re-valving it too.
From what they were telling me is a lot of people suffer from the shock actually blowing up, so just having the bolt coming out is pretty lucky.
dukemerc
- Dec 7, 2012
thanks for the feedback guess now all i do is pick one and get it done think ill get both done and another thing changing these front end bushings is getting old any suggestions there thanks duke
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Pioneer Performance sells a good aftermarket replacement. I prefer theirs over the oilite version.
rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
Just sent my shocks to schimdt bros. Trying someone different plus there kinda local cuts shipping cost.
dukemerc
- Dec 7, 2012
thanks again one more question i have 5000 miles on my nytro and i see some white lines of tread between the lugs when do you know a track is shot the lugs are fine its just every couple of spaces the white tread is showing thanks again for all your help... duke
Dodge Ram
I used Hygear this year.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I got just over 5000 miles on the stock track. It didn't show wear like you're describing but it had lost many of it's lugs so I decided it was time for replacement. If you do a replacement I highly recommend installing a 128" track with the Star skid relocation kit: http://www.ty4stroke.com/viewtopic.php?t=112741
