newtayami
Hey Guys
I bought my wife an 08 LTX-GT Apex and I had it out yesterday.....it has some Dalton clutching, 1.250 ripsaw studded...has great mid range.
But it spins and doesn't transfer well at all....it has the electric shock and I tried it in many positions, but spins horribly even up to 40mph....
I am no stranger to setting up sleds, and drag sleds, but this is our first 4 stroker.....Any help would be appreciated.
SharkAttak
i was running 1.325 studs 144 of them in my Attak ripsaw 1.25, couldn't hook-up for nothing, changing to 1.450 or going with a 1" track with 108 1.175 studs, haven't decided yet
big_red1a
cobra 1.325 with 198 gold diggers 1.450 run track to spec tension and hold on tight!
SharkAttak
big_red1a said:cobra 1.325 with 198 gold diggers 1.450 run track to spec tension and hold on tight!
that will do it, how much top-end do you lose?
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
Have you adjusted the transfer rod? That makes a huge difference. I have 192 1.450 studs in mine wth Ulmer Clutching. The sled hooks like a bear...not for the faint of heart. I lost a bit of topend with my gear chage but I have way more fun like it is now.
SharkAttak
Phazernut said:Have you adjusted the transfer rod? That makes a huge difference. I have 192 1.450 studs in mine wth Ulmer Clutching. The sled hooks like a bear...not for the faint of heart. I lost a bit of topend with my gear chage but I have way more fun like it is now.
that must really hook good
big_red1a
not sure i have several speed scrubbers:
simmons dual carbide skis
snow scratchers on skis
fat boy spring rear end is higher
bergstrum triple pts
whal bros extroverts
cobra track
And a healthy appetite
i see 99mph gps
cobra track
i see 99mph gps
darv
- Aug 9, 2005
- 08 Apex 40th LTX
i have the same sled as you do you must make sure you set the sag to 40-45mm and i set my transfer rod to 1/8 from max boy does this thing hook up , i also put C&A pro razor ski on stud boy 6" carbies on very happy the way it rides
newtayami
New to Yami like the name....but own and race drag sleds etc, so I can make adjustments where needed....How about a quick overview on the transfer rod set up, first Yami 4 stroker in the stable....Thanks
darv
- Aug 9, 2005
- 08 Apex 40th LTX
give me a call amd i will explaine what you have to do Jerry 807-274-6907
newtayami
Will do once I get the sled inside and thawed out Jerry....Thanks A Lot!!
Brent
Brent
badlarry
Pred rilled 1" hacksaw w/ 144 1.175 gold diggers hook up pretty good. Lots more bite over my 1.375's in my 1 1/4 ripsaw from factory.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
The transfer rod is pretty simple. It is the single threaded rod in the center of the skid. The more to lengthen it the more weight transfer you get. Most noticable on acceleration. More transfer means more ski lift. I found I had to play around with it to get what I wanted. Right now unless I really bounce on the back, when I hit the gas my sled lifts the skis about 6 inches and takes off. It settles back after a few sled lengths. There should be a marked rod in your tool kit to help with its adjustment. Its explained in the owners manual. Go here to download my free sevice manual for the Apex.
http://www.filesend.net/download.php?f= ... 03aa72011a
Feel free to ask any other questions feel free to call as well. Craig at 709 682-8245.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
SharkAttak said:Phazernut said:Have you adjusted the transfer rod? That makes a huge difference. I have 192 1.450 studs in mine wth Ulmer Clutching. The sled hooks like a bear...not for the faint of heart. I lost a bit of topend with my gear chage but I have way more fun like it is now.
It is definately not for the faint of heart on a hard packed trail. Grab a handfull of the go flipper and you grin for a long while....
apexg88
Phazernut said:The transfer rod is pretty simple. It is the single threaded rod in the center of the skid. The more to lengthen it the more weight transfer you get. Most noticable on acceleration. More transfer means more ski lift. I found I had to play around with it to get what I wanted. Right now unless I really bounce on the back, when I hit the gas my sled lifts the skis about 6 inches and takes off. It settles back after a few sled lengths. There should be a marked rod in your tool kit to help with its adjustment. Its explained in the owners manual. Go here to download my free sevice manual for the Apex.
When messing around with the transfer rod how many turns do u recommend at one time, is it very touchy if you turn it a lot or do u need to really crank it up to notice the difference?
