weirdo
- Dec 15, 2019
- Sydenham
- Nytro
No head light or tail light.
I have replace the head lights, relay, fuse 20amp
checked grounds I could only find two. Under the air box to the left. Other is in front bolted to the regulator assembly. Is there other grounds somewhere I’m missing I still have NO head lights
there are ground blocks hidden in the loom that can go bad.
weirdo
- Dec 15, 2019
- Sydenham
- Nytro
Thank you for taking time to answer my question but I’m a little confused about a loom.
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
The loom is the wiring harness.Thank you for taking time to answer my question but I’m a little confused about a loom.Th
