adirondac blue
I have a cobra track on a 08 nytro, can I run 1.45 or 1.5 with the factory tunnel protectors.
yamahahaha
either
yamahahaha
either
gmfamily2008
just be sure to watch your track tension. need to keep it tight
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I would highly recommend 1.45 studs. I'm running 114 of 1.375 in my XTX and at this point am considering changing them out to to longer 1.45 for additional penetration. I have ran 1.45 in my Apex and the additional length makes a tremendous traction difference.
sleddingfarmer
I'm running woodys megabites 1.450 in my cobra and they get plenty of penetration. I would not recommend the 1.50... clearance is tight and the little bit of extra traction would not be worth it if you start hitting your front heat exchanger. I only can speak for the woodys 1.450...I dont know if every manufacture measures their studs the same.
YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
Definately the 1.45, I have them on my nytro and it hooks up great!
