Mazz
- Apr 18, 2010
- Esko, MN
- 2008 Fx Nytro RTX 40th
Has anyone else noticed any wear on their line connecting the center shock to the oil reservoir ? Mine shows a little wear as though a front ideler wheel has been rubbing on it. My only solution so far has been to zip tie the ends of the spring to make sure it stays in the proper position to guard the hose. Just wondering if anyone else has experinced this and if so what solutions are there, thanks.
nytroman20
My bolt fell out lastyear. They replaced on warranty. $600 shock. Maybe check to see if it's tight.
Mazz
- Apr 18, 2010
- Esko, MN
Are you refering to the bolt for the shock or the hose clamp on the reservoir? Just as I'm typing this and thinking about it, could you loosen the reservoir and slide it back to get the hose away from the wheels?
nytroman20
I'm talking about the bolt on the shock. U may be able to move it back some or put a tie wrap on it.
Mazz
- Apr 18, 2010
- Esko, MN
While going over and checking the suspension was how I found te issue to begin with, Thanks for the ideas nytroman I have to get in the shop and check it out again.
nytroman20
No problem! Good luck!
