SLEDNECK67
Woodsrider: will i have to add support bracketing for the running boards if i am going to air frame boards
pro116
Hartman makes a tunnel extension to convert it to a tapered one.I have a brand New one I will sell.
swelly
OK, sorry for the mess in the Garage, but here are some pics. I cut the running board right behind the CR Drop Brackets. They have a ton of support so no worries about bending.
I used a long Rev bumper to hopefully keep some support. Not to mention it was 5 bucks at the salvage yard.
SLEDNECK67
Swelly- Thank you now i am wondering if the factory brackets will give enough support? if i cut the same way you have .
swelly
I don't remember how well they support the actual running board. They are big enough for sure on the tunnel side of life.
SLEDNECK67
Swelly: if i am adding skinz airframe boards should i need to worry about the support of the brackets for the running boards then
swelly
SLEDNECK67 said:Swelly: if i am adding skinz airframe boards should i need to worry about the support of the brackets for the running boards then
Not sure, maybe some one that has installed a set will chime in. Those boards are supposed to offer a ton of support. But after thinking about it, from all the pics I have seen of the Airboards. You would be eliminating the stock running boards, so doing a taper would just compliment the sleds performance.
SLEDNECK67
That's what i was thinking swelly. I hope some one chimes in but i was thinking of doing a longer bumper for support like you.
Lococoin
I am in the process of installing 08 airframes, 2010+ skinz bumper, and a Hartman 153 to 162 extension on an 08. I am still waiting on the extension before I start, but I am hoping to somehow use the bracing that comes with the extension to strengthen the rear of the tunnel. It's more for carrying gas, etc back there. From what I've read you won't need any running board support as the airframes bolt up high at the back making them very rigid.
snownutz
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
Air Frames do not require extra support that is not provided by the kit itself.
doo_man
SLEDNECK67
Merry Christmas guys and also you guys make it easy to do custom stuff to my sled everyone replys with great info i really appreciate it guys
swelly
That is the nice thing about this Forum, it is all fun. Lots of help and advise. We even let traitors stay on board and just pick on them a little.
