Yammerhead
I'm going through my skid and have a couple of idlers that need to be replaced. Looking the the fiche, the front shock idlers have different part numbers than the rail idlers. Looking at them, they all have the same diameter, width and bearing. The two on the front shock are more rounded off, which I'm guessing has something to do with running inside the track nubs.
8ET-47310-00-00 Front shock idlers
8FR-47310-01-00 Idler on torsion spring slide and rear idler
I know you can get the slightly larger aftermarket ones with replaceable bearings. Have guys used these on the front shock idlers or should I stick with OEM?
