bluegrass
- Mar 6, 2007
Am I going to see much difference between a 1.25 track and a 1.75 track on groomed trail I found a good deal on a 12 nytro xtx but it has a 1.75 track and not sure that it is the right one for me I don't wont it ride ride #*$&@ on the grommets trail because of that.
fxnytro1050
IMO i would think on a groomed trail a 1.25 would be better then a 1.75. better again stud the 1.25.
ive used the 1.5 intense and to me it worked well on and off the trail. I wouod think a 1.75 would be ti far the other way.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I like the cobra track the best 1.34
Boston RX1
If you have snow that is not rock hard packed or icy, it is a great track for the trail. If not, you are going to have your hands full. Most of the time these past 3 years I have had good conditions for the track. I just came back from a weeks ride in Old Forge where there was little snow and very hard icy conditions and I was holding my breath that I would make the corners. Just depends on the conditions where you ride.
blurider2
- Jan 26, 2013
- 2013 NYTRO XTX TURBO
i ride my 2013 xtx 1.75 on the trails all the time. went from apex to nytro ride is fine just run ice scrapers on a arms and on the suspension no problem with sliders over 1000 miles.
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
You can always trim it to a 1 1/2" and have a track that no one else has. If you are strictly a trail rider then you really don't need it. I have a 162 MTX with a 2 1/4" track trimmed to 1 3/4" and I ride the groomed trails at times. Our trails don't really get icey. If they do I just try and take it slow and chase every bit of loose snow I can find until I am in better conditions.
fxnytro1050
why would you do that??? seems like a waste of money to me. the backcountry track would probably be better the a 2.25 trimmed to a 1.75.
lawmanbsi
trimming the track down is a pretty cheesy job. get a 1.5" steel bar. sharpen the back side of a saws all blade. set the bar on the track and bun the blade across it. if you want to cut notches in it weld a razor to a set of pliers.
http://www.youtube.com/watch?v=IeCpl8Dh7FI
nitris223
- Nov 18, 2012
- Yamaha Nytro MTX
fxnytro1050 said:why would you do that??? seems like a waste of money to me. the backcountry track would probably be better the a 2.25 trimmed to a 1.75.
I trimmed down a 2.25 track because there is no 1.75 track offered in a 162 length. I bought a MTX because I couldn't find a used XTX at the time. 2.25 tracks are overkill here in the flatlands and it is also the stock Maverick track that fold over. Trimmed to 1.75 makes it handle better on the trails and the lugs are stiffer. If I bought a powder claw I would do the same thing. Camoplast thiks that nobody rides a mountain sled in the praries. There are more longtrack sleds here then short track sleds. Just 3 tracks to pick from for the 162 3 pitch.
