Nytrider109
Could i add 1.750 studs on my 2008 fx nytro rtx? let me know thanks
BADSLED said:I wouldn't recommend you run anything longer then a 1.450" stud.
tapex_07 said:Im running a 1.75" on my 08 RTX. I usually check under the tunnel and heat exchanger after every ride. No nicks or scrapes.
BADSLED said:You have to be clear how you are measuring your studs? Overall length from base of the stud to the tip or going by manufacturers specs which is usually exposed stud past the track. If it's an overal length you are reffering to you will be fine.
gmfamily2008 said:BADSLED said:You have to be clear how you are measuring your studs? Overall length from base of the stud to the tip or going by manufacturers specs which is usually exposed stud past the track. If it's an overal length you are reffering to you will be fine.
X2 , What kind of studs are these ? and is the manufacturer calling them a "1.75" or is this the overall measurement ?
