1000ft radar runs setup
bedwet
Rice Lake Wi
Does anyone know of a good clutching setup for a all stock 03 rx1, weight springs cam gearing, thanks
this is for ice i just kinda want an idea where to start
For Drag Racing to 1000 ft. you may want to leave the stock gearing in. If it was only 500 feet, then I would consider replacing the top gear with fewer teeth, maybe even a 22.
The Drag n Flies seem to be working for weights. However, if you are thinking about a whole clutch kit, then I would check with Allen Ulmer and decided if the kit was going to be a Stage II or Stage III. I think if you ride out on the trails much at all, you would be better off with a Stage II Kit.
There are other suppliers of Kits out there. But, I have never seen anyone complaining about one of Allen's Kits, and I have seen some complaints and a lot of questions about other kits.
Just my thoughts. I have experience with the Stage II. I like it.
