100ll avgas, is it safe to run MPI says no????
rxwhopper
REGINA SASK> CANADA
very new to the supercharger,s and reading in the mpi book it says not to run av gas. was wondering what the problem would be or if i even need it. i am running 7 lbs boost on a mpi stage one on a 06 attak. we are at about 2000 feet here in sask. am i safe with premium or should i add some av gas?? thanks for the info as like i said am green to the boost.
What he said -- at 7 pounds you are fine if you go up in boost and use AV gas use it straight. It is made for boosted engines and works perfect.
3 years with a turbo 14 to 18 pounds one extra head gasket 0 problems lives on straight Av gas.
If you burn av gas say bye bye to your o2 sensor.
The same goes for any high octane race fuel--- all the real good stuff has lead too.
By the way the sensor will last plenty long enough to dial in the sled .
Once dialled in I just ride the heck out of it :-o
cheers.........
