121 to 136 conversion
schroedermn
Lakeville, MN
Okay, someone make my life easy, I'm want to change from a 121" to a 136" skid. I've looked at Hartman, MPI, others
1. Does the suspension move down and the seat up when you put a 136" track on?
2. Does anyone know a shop in the Minneapolis area (within 70 miles)
that will install the extensions, put on the track, and put on the tunnel extensions.
I'm also want to raise the handlebars 3" to stand up in the bumps, should I just order up the 2" riser with a the pivot kit?
Please feel free to post links to the stuff I need as I want to order up these things today sometime.
****Also, if anyone has the FRONT shock part that holds the springs in place (Bottom by the ski) please PM me as I need one. I ordered shocks from a guy here in the classifieds and he didn't include this disk that holds the shock spring in place.
Call Joel Schneider in Albany, MN.(about 80 miles NW of Minneapolis on 94). He will help you figure it out. 320-845-4856 Joel Schneider Service. He helped me do a 136 Expert-X, Ripsaw, MPI conversion last year and he can help with all of your clutching needs also.
