schroedermn
Okay, someone make my life easy, I'm want to change from a 121" to a 136" skid. I've looked at Hartman, MPI, others
1. Does the suspension move down and the seat up when you put a 136" track on?
2. Does anyone know a shop in the Minneapolis area (within 70 miles)
that will install the extensions, put on the track, and put on the tunnel extensions.
I'm also want to raise the handlebars 3" to stand up in the bumps, should I just order up the 2" riser with a the pivot kit?
Please feel free to post links to the stuff I need as I want to order up these things today sometime.
****Also, if anyone has the FRONT shock part that holds the springs in place (Bottom by the ski) please PM me as I need one. I ordered shocks from a guy here in the classifieds and he didn't include this disk that holds the shock spring in place.
_________________
Lakeville, MN (RON)
_________________
Lakeville, MN (RON)
black john
spring holders
i needed one as well what i did was got an old set of ski doo shocks and cut the center out of those to match the yamaha shocks. they have a deeper pocket and a retener/stoper in the center as well. shocks were free and a little time and i was up and running again.
schroedermn
Thanks. Guy I ordered shocks from is shipping the parts
Thanks for the skidoo trick, the guy who sold me the shocks is shipping the parts as of yesterday. Hopefully they are on my sled before Friday morning which is when we're leaving for up North again (Lutsen,MN()
rx-1 blue reverse
As for the Handlebar risers on the 03 & 04, 3" will require cable ext. I went w/ 2" and also narrowed the handlebars by 2" so my cables were fine. With the stock cables 1.5" works good. The 05 has longer cables.
schroedermn
2" riser
When adding the riser are you still supposed to be able to see the instrument cluster? I can't, man I must be a big-time beginner here, OR do I need to add foam to the seat to see how fast I'm going again?
- 7K
