ebockus
I did ulmer air box mod, exhaust mod and put a fuel controller on it. i have the bottom and top and wot perfect at 12.5-12.8 air fuel ratio. but at about quarter to half throttle i have a lean spot of 13.3-13.5 riding at 90-100km/hr. it starts at 8500 rpm like a switch. 8400rpm 12.8 then 8500 rpm 13.5. Every time. i maxed out the fuel on the controller mid range still 13.5ish. Like i said it quarter to half throttle. IS THIS TOO LEAN? PLEASE HELP LOL wide open throttle is mint at 12.5 so no worries there
kuvasz
that's fine!! if you went to the turbo/supercharge section you would have found your answer right away. quarter throttle 13.5 you won't blow your sled up, wot throttle maybe a different story. mpi states you should run a supercharged engine at 12.0-12.5 wot. i run mine at 11.2 because engines are $7000 to replace and fuel only cost $20 a gallon. i used to run my sled lean all the time and it was fast before the mpi, check my previous postings.
ebockus
Thanks. i tried search but i guess i need to look harder. thanks agian tho
