snowmanx
I want to put the Hartman inc. 136" Nytro track kit in my new 08 Nytro. I was wondering if anyone has used this kit in their Nytro, and I would like to go to a 1.5" ripsaw track when I make this conversion. Has anyone put a 1.5" track in a 08 Nytro? is there clearance problems? Thanks in advance
got the exact kit on mine, 150 miles on it isw all but I luv it. Kit is very well done, but you either have to notch the track or take the tunnel protectors out.
snowmanx
That's what i was wondering I still want to be able to stud it ( I can buy studs long enough) so cutting out the front heat exchanger protector is not an option. Maybe make myself a smaller one to fit in the stock ones place?
I don't stud, but I just cut the track so I could stud if I wanted to . YOu can't tell were the track was notched if u don't know what to look 4. Maybe stick with the 1.25 cobra which has better soft snow performance than the ripsaw if you want to stud it anyway.
Fasttoys
i have a tracks usa kit from ulmer racing and i installed a 136 1 1/2 ripsaw it clears by only about 1/4 in the front of the track. i only have 20 miles on mine i like it so far
i think it makes the sled look bigger
http://www.ty4stroke.com/viewtopic.php?t=47826
snowmanx
I just ordered a 1.352" camoplast cobra 136" track for my nytro - i am going to stud it because of all the icy logging roads we run around here. I'll just have to modify the heat exchanger protectors to fit my new track. or cut the track lugs a little under the protectors - it does look like the 1 3/8 track my fit without any mods
Kråkan
my 1,5" ripsaw fits like a glove... The corba should fit just fine...
Alatalo
- Jan 11, 2005
I have just installed a fully clipped 1.5" Intense (Camoplast part number 9930C) together with Ski-Doo 9Tx2.52 extroverts (Ski-Doo part number 504152503). This combination does not really fit. The track lugs will rub the heat exchanger stud protectors quite bad unless you remove them (or notch the track lugs). With the Ski-Doo extroverts installed, maximum lug height is approximately 35 mm (1.38"), anything higher will rub the heat exchanger stud protectors. Though, no worries about the tunnel stud protectors, they are far away...
