Stretching to 136
mcamzr
Armada MI
So I’ve had some 136 tip up rail extensions for a couple years now and I am finally going to stretch the Nytro to 136 this off season. I plan on going with the 136 tip ups and a Intense 1.5 track from the stock 1.25 Ripsaw. Question is should I do a gear change as well? Current set up is a Schmidt brothers stage 2 clutch kit. Thanks in advance for the help.
based on older sleds i did that to, i would leave it alone for gearing. usually just had to adjust the clutching.
I run Schmidt bros stage 2 and stretched my RTX to a 136" with the Ice ripper track. No gearing or clutch changes needed.
I've seen failures with the Ice Storm track when they first came out. Hopefully that's no longer an issue. I'd like to install one on my Viper.
Wife's nytro has the 1.5 intense 136 with stock gearing. Seems a good match.
