Yama 1000
- Sep 2, 2011
- Rochester ny
- 2015 viper LTX DX
I'm interested in installing a 136 track on my rtx. I wanted to know what other people that have done it. What's the best track , tunnel and rail extension to go with. Also how many studs are you running. Any info would be great.
Nine2Nine
Yama 1000 said:I'm interested in installing a 136 track on my rtx. I wanted to know what other people that have done it. What's the best track , tunnel and rail extension to go with. Also how many studs are you running. Any info would be great.
OFT ext and a track to suit your riding style, I went with the 1.25" ripsaw again and wonder if the 1.375" Cobra might have worked better. PM me if you need any other info.
sleddingfarmer
I went out to 136 on my old rtx SE. I was very happy with it. I didn't really notice any 'bad' effects of the extra length. Just more traction, and enough room on the tunnel for a tunnel bag.
I used Tracksusa.com rail and tunnel extensions, and I'm happy with them. OFT sounds to be extremely good as well. I went with the Cobra track, and its really the only option right now besides the Ripsaw if you want to run studs. If you could find a 1.25" Predator I would recommend that track, but good luck finding one. I ran 144 studs.
NFLD-Nytro
sleddingfarmer said:I went out to 136 on my old rtx SE. I was very happy with it. I didn't really notice any 'bad' effects of the extra length. Just more traction, and enough room on the tunnel for a tunnel bag.
X2! I don't know why they stopped making the Predator, it's a MUCH better track than the Ripsaw, which, IMO, is useless for anything other than groomed trails, and not very durable.
LSXM3
I also did the OFT136 extension kits as it is the best IMHO of ANY extension out there. I went with an arctic cat SILENT SERIES 136" ripsaw with the 8" big wheel kit and i love it so far, I have only got about 10 miles on this year as we havent had any snow!
Is there any advantage of 136 track for trail only riding? I was thinking about the change from 121 but I'm not sure if there is any upside.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
NFLD-Nytro, ripsaw not very durable? best ive seen in that department! ive seen predators and cobras that wear very bad in low miles
shadow44
krysFly said:Is there any advantage of 136 track for trail only riding? I was thinking about the change from 121 but I'm not sure if there is any upside.
It will bridge the bumps better.
LSXM3
shaddow44 said:krysFly said:Is there any advantage of 136 track for trail only riding? I was thinking about the change from 121 but I'm not sure if there is any upside.
Not only that but it also offer additional traction as you have more "LUGS" in contact at any time.
Im not sure about the others but OFT's are tip up rails as well
multi sled
i think the 136 makes the shorties ride better,and if you are trail riding and you want to do some boondocking at least you have a pretty good chance of getting back on the trail i went with the 136 from oft it's got a tipped up rail.it seems to be a pretty solid kit,the only thing i would add is a wheel kit at the bend of the tipp up.krysFly said:Is there any advantage of 136 track for trail only riding? I was thinking about the change from 121 but I'm not sure if there is any upside.
shockwave
- Feb 25, 2010
- St Paul d'abbotsford Québec
- 09 Phazer RTX
Like most of the guy here I went with OFT 136 and an Intense 1.5 track. This is one huge improvement for me. You will not retreat it.
