ICULOKIN
was just offered a new take off 153 mtx skid and track for $500.anyone know what is needed to make this work in a xtx?
Apex & xtx
im not exactly sure on all the parts you need but i think after its all said and done you might be better of selling your xtx and buying a Nytro Mountain you might save your self alil coin. But $500 for that is a good deal
Butta
ICULOKIN said:was just offered a new take off 153 mtx skid and track for $500.anyone know what is needed to make this work in a xtx?![]()
Check the clearance at the drivers. I don't think there would be an issue, but out of the factory the tracks are very different lug heights, so if Yamaha decresed the clearance on the XTX to provide the same track to cooler clearance as the MTX stock, you would have a problem.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
You will need mtx drivers since the mtx track is 3.0 pitch vs 2.52 pitch of the xtx and I think the mtx has 7 tooth drivers vs the 9 tooth of the xtx. I think 7 or 8 tooth will be needed for clearance.
