Can you run a 16"-1.5"  track on an '05 Warrior?
Have to change anything?
LazyBastard
Make sure you cut off all the projections into the tunnel. There might be some bolts around that could snag. Also, some aftermarket drop brackets may be needed as they are thinner than stock for more clearance.
