ded moroz
I have brand new Camoplast Cross Country track 136 x 16 x 1.75....It for MXZ Renegade...
I wonder if anybody know if it will fit 05 RX1 Warrior???
I've heard the reg RX1 can take MAX 1.5 lug height....+ its 16 inch wide (1 inch wider) then usaully...
If it would fit, which I think NOT....It would of been great!!! then I would also need to lower my gearing...
What is stock gearing on 05 RX1 Warroir???
Thanks...
Thanks...
asrx600guy
The width should be ok
per ADBoivin ExpertX installation guide
Skidoo REV Summit 16 3/4" inside tunnel width
RX1 16 9/16" inside tunnel width (same as all other newer Yamis)
Its only 3/16th of an inch narrower something like 5mm if my brain is working.
the lugs should be ok
The 1.5" max may be with the stud protectors (an SRX can run 1.5" w/o stud protector and 1" with stud protectors)
the RX1 can run at least 1.25" w/ studs
get rid of the tunnel and heat exchanger protectors and 1.75" should be do-able. you will loose some top end, don't know how much
now for the disclaimer :?
I don't realy know my a$$ from a hole in the ground when it comes to the RX1. I'm just looking at the availble info and making some conections. hopefully someone with first hand info can tell you more.
btw 1m is a little more than 3 feet, once again if my brain is working this morning
JDKRXW
Although the track will fit in the tunnel, I'm pretty sure you're going to have have problems with the drop brackets. You should move this thread to the mountain section...... where lots of guys have put 16 inchers on.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
16" track will not clear the rear mounting brackets. I believe there is about 1/4" space between the track and brackets right now.
BADSLED
- May 13, 2004
- Syracuse, NY
POWERHAULIC
Rear drop brackets are the problem
