attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
Hey... I was wondering would a 16" x 136" track fit on a '06 Attak? Or will there be issues for ice build up in the tunnel? Thanks in advance for any help!!
Super Sled
- Feb 25, 2009
- Summit X
You could get one in there, but i bet it would rub on ice that builds up. If you didn't run studs I'd recommend just removing the tunnel protectors before you install the wide track.
attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
I would like to run studs if possible... Guess I'll have to go back to a 15"x 136" again.. Thanks for the suggestion!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
You can but you need different rear mounts for the skid. You can run studs but you may need smaller drivers.
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
I remember reading a post on here a couple years back about a guy that done this it was a tight fit but he did get it to work. I wouldnt even think about going 16'' wide on my attak, those things are hard enough to maneuver around as it is seeing its so heavy a wider track would make it worst. I even went to 15'' on my mtx wayyy better IMO.
attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
Thanks guys for the advice! I think I'm going to go with a 1.75" backcountry instead.. 15" wide. I overheated my old track n the lugs all came off!! LOL..
- 6K
