karlburns
- Oct 3, 2013
- Anchorage,AK
- 2011 apex xtx
2010 vector ltx gt
So I've been looking for the last year at new shocks for an 07 attak. It just has the standard coilovers with 7k miles on them. I found a set of fox floats 17.5"ctc I know stock is 16.5" has anyone tried changing to this setup? And if so how was the handling and ride performance afterwards.
Thanks to any and all for advice.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
I have 17.5 Float X's on My Turbo Apex
They seem to be fine. I run the pressure around 50 PSI and A arms are just a little above horizontal.
I am running the rear suspension in the bottom hole of the rear bracket to raise it a little for stud clearance on the Turbo.
This Sled is an animal and a handful with all the power & the other "Fast" shocks I had on it were 17.5" as well so I can not compare the sled with both lenghts.
My Stock Apexis a 128" track with Fox Float 2's and it is more fun to drive in the tight & twisties than the 144" Turbo. I'm guessing most of the difference is the track, Extra weight of the turbo & maybe me worrying a little bit about all that power under my azz when riding it in the tight & Twisties.
vanstone
I have them on a 2006 attak and they work great. Big improvement over stock.So I've been looking for the last year at new shocks for an 07 attak. It just has the standard coilovers with 7k miles on them. I found a set of fox floats 17.5"ctc I know stock is 16.5" has anyone tried changing to this setup? And if so how was the handling and ride performance afterwards.
karlburns
- Oct 3, 2013
- Anchorage,AK
- 2011 apex xtx
2010 vector ltx gt
Vanstone 17.5" or 16.5" ?
vanstone
17.5Vanstone 17.5" or 16.5" ?
