2 bottle system?
langow
West Bend, WI
I know I talked with someone who had run a bottle in the nose and another one in the trunk that were tee'd together to make 5lbs of fun. Can't remember who it was now. Anyway, what kind of tee would I need to buy for this? Anything special? Also, would the warmth of the trunk bottle help keep the pressure up through the entire system, including the bottle in the nose? Maybe a side benefit besides having twice as much juice with me.
heat from bottle would be a little higher then the other would just balance meaning if one bottle has 900lbs and the cold one had 700lbs you would be somewhere in between and Im thinking on the lower side. You can put a in line t anywhere in the line and connect to both. I did some playing around years back on my boat with twins. Performance was the same no matter how I t'ed the bottles. Just need a t to fit your nitrous line.
