BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I have a set of Heelclicker 2 speed weights weights I would like to try out on Nytro XTX. Looking for baseline recommndations for a starting point on tuning hardware placement and helix angle.
Turk
Tech Advisor
Try this
black hc primary spring
1 bolt 2 washers in heel
rest of weight empty.
45 or 47 helix will give better aceleration.
BADSLED
- May 13, 2004
- Syracuse, NY
Have you run these with the 14.5mm rollers? I noticed the weights are 2mm shorter then stock weights.
Turk
Tech Advisor
yep..i have. i run em right now in my turbo sled & my apex xtx.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
BADSLED said:Have you run these with the 14.5mm rollers? I noticed the weights are 2mm shorter then stock weights.
I thought I remember you running the Rat weights? What's up?
BADSLED
- May 13, 2004
- Syracuse, NY
Grimm said:BADSLED said:Have you run these with the 14.5mm rollers? I noticed the weights are 2mm shorter then stock weights.
I did try the Super Rats, but wanted to try 2 speed setup before the season is over.
rrxx-1
He sold them to me, lol...........
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Weren't impressed?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
if you want a holeshot and to pull ....you know what I said....
BADSLED
- May 13, 2004
- Syracuse, NY
What is the difference between the updated series series of 2 speed weights vs. original?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
original 40-10's were powder metal with an aluminum "hammer"...
the new is all billet steel and therefore...the hammer is 20 grams vs 10 grams...
the newer has a slightly less agressive profile...
BADSLED
- May 13, 2004
- Syracuse, NY
sj said:original 40-10's were powder metal with an aluminum "hammer"...
Thanks, SJ.
Turk
Tech Advisor
the original 4 stroke 2 speeds were 20/40. When they shaved 2 grams off the body of the main weight they worked a lot better to make them into 20/38.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yes turk you are talking of the second version basically while he was switching over to the billet steel....
the originals had a 10 gram aluminum hammer....
turk p.m. me when you get a chance on that update
nytro power
- Mar 7, 2011
any one know what y helix from hauck stand for
