2005 RS Venture-New Belt Squeal
Glock30
Anyone else have excessive belt squeal after changing to a new belt?
It is an OEM belt.
Only squeals when stopped.
No noise when engaged (moving).
You can do a quick search and find this question asked lots of times...along with the answer.
On the back side of you secondary clutch you will find 3 small bolts with contain a small washer (spacer)....pull each bolt, remove the space, and replace the bolt. Problem solved!
Put the spacers back in as the belt wears.
Yes you could do the washer thing, I just ride it and the belt seems to sit into the clutchs just fine after a couple hundred miles, just make sure you are not too hard on the new belt...
