2006 apex only idles
6000 miles on sled, will start up and idle fine but when you give it revs up to 5000 rpm it just cuts out all power, headlight shuts off, no codes
The cables were tight, and I assume that if it starts in the cold it shouldn't be the issue
I work on cars. So not too familiar with Apex. But a low voltage could still start but not have enough for engine sensors. If u don't have a battery tester. Try hooking a set of jumper cables to another battery. See if u get better results while revving.
Multi-meter test it at the jumper/charger leeds.
12v+ engine off
13.5-14v+ engine running @ 4,000 rpm
If it's not 13.5-14v+ @ 4,000 your stator might be going south.
