dave carpenter
I tried to bypass the torc on my sled last night and then today when I took it off trailer code 84 came on. How is that if the torc is bypassed?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
you must mean tors and if it is still comming up after bypass look at the speed sensor and the connection to the back of the speedo.
dave carpenter
Do you know witch wires to bypass? I heard the attack has black and yellow wires? And witch one do you leave disconnected? I will check speed sensor tonight.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
you have to disconnect two wires and connect them to each other im not sure of the color but they will be up by the throttle bodies.
dave carpenter
So I found the wires so I connected the2 together coming from harness will try it tommorow. My speed sensor looks good and bearing also perfect shape.
dave carpenter
so i figured out the Tors and also got ride of low idle and stalling by adjusting CO to -12 sled runs perfect now.
