zeke
i just purchaced this sled a couple of months ago, it only has 396 miles so i know it may take a few more miles to get the proper rpm out of it.i am thinking maybe i should change the clutch springs were they have been sitting in the sled for 3 years now and maybe have lost some tension. are there any well known spring changes to this sled that work better other than getting the full ulmer setup. if i like the sled i will probably do that next year.just looking for a simple and inexpensive increase in pull were i may change springs anyway.
thanks
thanks
Ram Air would be my first inexpensive mod get the air into in while testing we have seen 2-3 MPH gains when switching between stock lid and Modded lid just my 2Cents
CR10EK Spark Plugs
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Those stock springs will be fine. Just ride it and break it in and the RPM will come up.
CR10EK plugs work good and are worth a few HP. Gearing down one tooth on top, or two teeth on bottom also helps using the stock clutching.
email me and i will tell you what i have done with the help of the clutching master on here.......
