rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
Just spent last 4 days riding in michigan. If I am running the sled hard 70-80 mph the temperature on the sled will start rising I have digitial temp gauge installed. If I am running in woods at a steady pace the sled temp is fine what is normal operating temp?
I purchased sled used last year so thinking to.change antifreeze and check.thermostate if operating correctl. May even purchase rear exchanger for. More cooling. If anybody has any other ideas the help.would.be appreciated.
Here are a few mods that I have installed.
Full excell exhauste
Pcv with ignition module
Ulmer airbox mod and clutching
Cobra track
Cobra track
rear cooler will drop average temp 10-15 degree f. Even with a rear cooler on my 07 attak, 180- 190f is pretty common. really not unusual to even see 200f + at times. I was over 200f most of the time before the rear cooler install.
Paraclete
Rear heat ex. solved my heating problms
rayone02
- Dec 3, 2010
- adrian, mi
Thanks for the info. Did any of you change coolant before installing rear exhanger to see if that would help?
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
I had a similar problem. I completely emptied the old coolant and filled with new. Once I got all of the air out it has been fine ever since. I also had my rear crossover tube wear through on the tunnel which caused a slow leak. Just wish it was easier to check the coolant trailside, but at least you can with a couple tools.
CaptCaper
- Jan 1, 2007
- Northern N.H.
Yea cooler is the way. I had to add one to mine when new...Easy to put on.
If you have studs you'll have to add protection over the cooler I believe. That's a whole other story..
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
first be sure you have 50/50 in the tank if not it will run hotter. if that dont cool it off enuff then add rear cooler. most have found that the 50/50 was enuff.
rayone02
- Dec 3, 2010
- adrian, mi
Draining coolant is first thing I am doing.
Big Daddy SRX
- Feb 24, 2006
- Reese, Michigan
- 2018 Sidewinder LTXDX,2014 SR Viper, 2012 Vector LTX, 2011 Apex XTX,
- Reese, Michigan
- AOL
- reesetrailer@aol.com
Put the rear cooler on. It not only cools better on low snow conditions and warmer temps, it also eliminates ice build up at the rear. I have two 2006 136" Attaks and installed the Yamaha rear cooler. It is bigger than the standard Apex cooler and fits nice. I am not studded so I just cut the tunnel protectors off at the rear to give me enough room for the cooler and about an 1/8" gap.
rayone02
- Dec 3, 2010
- adrian, mi
I was going to cut off stud protectors from tunnel but didn't should of. This summer will.do that along with rear heat exchanger.
