Ak Yammy
Just picked up a used 07 Rtx and am having some serious throttle bog.
If I nail it from a dead stop it falls on it's face and almost stalls. If I squeeze the throttle semi-slowly it's much better but if I nail it hard it cuts out very bad. also if I raise r's up a bit (2000 or higher)it's better and if I spin the motor on some ice (no load) the bog is almost non existant.
I thought I might just need to do the co trick but I went into Di mode and found a code 22 for the airbox sensor could this be related?
Also found a code 30 (yikes low oil pressure). Is the 30 anything to worry about as far as did the previous owner(s) possibly damage something or does the sled have enough of a failsafe to shut it down before things are damaged? I assume this usually comes on when the sled is tipped over?
Sled only has 1800 miles is bone stock and runs great aside from this nasty bog.
Sorry for so many questions love the sled just want it to run right.
Any help is appreciated, this site rules!!
Ak Yammy
Bunp to this. Anyone???
