bog
Csellors
Winnipeg, MB
i have an 07 attack that is stock with 5000 miles on it. I just bought it and it has a bog if you give it a lot of gas off idle. Once it is moving, it is fine. I am going to run some sea foam through it. What else could the issue be? Thanks.
what about old fuel?? my apex does this every year for a bit. seafoam wont hurt.
A little seafoam and a new set of plugs and you'll be all set. It probably just needs some fresh fuel, new plugs and some seat time...
Thanks a lot, new belt, ran a tank of gas with seafoam and it still does it. I will check the primary spring.
