kimcoop1324
I own a 2007 apex gt attak. I replaced the worn slides with a set of dupont ones. After I reinstalled the rail / suspension and adjusted the track tension I noticed while pushing down on my rear bumper and compressing the suspension it didn't return to the Original height. My sled has 900 miles on it and I can't believe the rear shock is blown. What am I missing? Any help would be great.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
If you have the ohlins in it try turning your rebound adjustment knob to see if you have all the clicks. If you do ride it.
kered
I just had mine rebuilt. What is the original height im curious?
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Rear suspension height is set by the spring, not the shocks.
Make sure your sled is flat on the floor, not on dollies. Dollies really mess up rear suspension height.
ApexSE/Vector
- Dec 12, 2010
07 with 900 miles?
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
If you figure it out let me know because mine is the same way .
kered
Just had mine rebuilt at 9000 kms and when I compress the suspension it doesn't come all the way back up? There is still a bit of lift when you pull up on the rear bumper?
