Kjax2710
- Jan 18, 2015
- 2008 Yamaha Nytro FX
What is the Bearing called that is behind the Secondary clutch? I know this is the jackshaft so would it be the "Jackshaft Bearing PTO side" I have been sent the wrong one twice now and its getting a little aggravating they keep sending me the driveshaft bearing. Thanks in advance.
Dr. FeeLGooD
Secondary shaft axle bearing 93306-20656-00
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Why not look up the part number, say on Portyamaha's site, and specify exact part number when you are ordering. You can double check this, but I am getting part number 93306-20656-00 for the jackshaft bearing for 2008 Nytro FX. So, just to confirm, that is the upper bearing on the clutch side. And you are saying, they are sending you the lower bearing with set screws on it?
X2 what Doc says.
X2 what Doc says.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Never order bearings through yamaha unless you're stuck. Take the old one in and find a bearing supplier. He'll be at least half price. I guess if you're 100 miles from no where then it wouldn't pay to drive in but otherwise its a easy way to save some money. Plus you're guaranteed to get the right one.
Kjax2710
- Jan 18, 2015
X2 what Doc says.
Yes that is the part number I finally received from Yamaha after they sent me the wrong one twice (yes lower driveshaft bearing with the set screws). Thanks for the help.
Kjax2710
- Jan 18, 2015
That's the plan at this point.
cloead
- Mar 8, 2013
In the future I recommend looking up the part number yourself. That way there will be no one else you can blame and you will get back to riding faster
NS FX NYTRO
Everything I order is by part number I looked up. After you read parts guy the part number get them to tell you what the part is to ensure they typed The number in right or you didn't screw up number.
